ACME-DNS Credentials
I’ve setup a selfhosted ACME-DNS Server (https://github.com/joohoi/acme-dns) which is running fine. Used acme.sh to create and renew Certificates. Now I want to use certify. But I can’t find where to put the Settings got from the REGISTER ( curl -X POST http://auth.example.org/register) command
Hi, I think the easiest way is to just use acme-dns normally in certify without reusing credentials (just hit Test to register and be promoted for the cnames values to create) but I haven’t tried transferring credentials from another client into Certify.
There possibly is a way to do it, domain specific config is kept under c\programdata\certify\acme-dns (from memory, I’m on my phone).
To be clear, Certify self-registers for acme-dns, you just need to request the certificate then populate the CNAME as prompted, then request the cert again.
