Hi We are using the letsencrypt with certifi the web 5.3.0.0 on Windows server 2012 R2 till today was all ok but from today we canot renew the certiface come only this error.
i am not any profesional can someqone help me with this situation?
LOG ERROR from APP
2021-12-19 21:49:52.712 +01:00 [INF] Default Web Site: Request failed - Failed to build certificate as PFX. Check system date/time is correct and that the issuing CA is a trusted root CA on this machine. :Certification path could not be validated. System.Exception: Failed to build certificate as PFX. Check system date/time is correct and that the issuing CA is a trusted root CA on this machine. :Certification path could not be validated.
at Certify.Providers.ACME.Certes.CertesACMEProvider.ExportFullCertPFX(String certFriendlyName, String pwd, IKey csrKey, CertificateChain certificateChain, String certId, String primaryDomainPath) in D:\a\certify-service\certify-service\src\certify-build\certify\src\Certify.Providers\ACME\Certes\CertesACMEProvider.cs:line 1312
at Certify.Providers.ACME.Certes.CertesACMEProvider.d__34.MoveNext() in D:\a\certify-service\certify-service\src\certify-build\certify\src\Certify.Providers\ACME\Certes\CertesACMEProvider.cs:line 1185
— End of stack trace from previous location where exception was thrown —
at Certify.Management.CertifyManager.d__17.MoveNext() in D:\a\certify-service\certify-service\src\certify-build\certify\src\Certify.Core\Management\CertifyManager\CertifyManager.CertificateRequest.cs:line 925
at Certify.Management.CertifyManager.d__16.MoveNext() in D:\a\certify-service\certify-service\src\certify-build\certify\src\Certify.Core\Management\CertifyManager\CertifyManager.CertificateRequest.cs:line 717
at Certify.Management.CertifyManager.d__14.MoveNext() in D:\a\certify-service\certify-service\src\certify-build\certify\src\Certify.Core\Management\CertifyManager\CertifyManager.CertificateRequest.cs:line 429
