I’m trying to create a certificate for my domain www.cinbalans.nl.
But when I do so he is looking for the validation file in the directory …/.well-known/acme-challenge/ but when I go there certify is uploading this file to this destination, but deletes the file when it’s done being used. That’s I assume the reason that I ma getting an error.
If I go to letsdebug.net I get the following error:
But if I ping my domain, then I get the result that all packages are received.
2021-01-03 14:08:05.310 +01:00 [INF] One or more tests failed
2021-01-03 14:09:01.713 +01:00 [INF] ---- Beginning Request [www.cinbalans.nl] ----
2021-01-03 14:09:01.718 +01:00 [INF] Certify/5.2.1.0 (Windows; Microsoft Windows NT 6.2.9200.0)
2021-01-03 14:09:01.744 +01:00 [INF] Beginning Certificate Request Process: www.cinbalans.nl using ACME Provider:Certes
2021-01-03 14:09:01.744 +01:00 [INF] Requested domains to include on certificate: cinbalans.nl;www.cinbalans.nl
2021-01-03 14:09:01.745 +01:00 [INF] Beginning certificate order for requested domains
2021-01-03 14:09:01.779 +01:00 [INF] BeginCertificateOrder: creating/retrieving order. Retries remaining:2
2021-01-03 14:09:03.594 +01:00 [INF] Created ACME Order: https://acme-v02.api.letsencrypt.org/acme/order/48032717/7101051816
2021-01-03 14:09:03.887 +01:00 [INF] Fetching Authorizations.
2021-01-03 14:09:06.503 +01:00 [INF] Got http-01 challenge https://acme-v02.api.letsencrypt.org/acme/chall-v3/9708567618/nyAaQg
2021-01-03 14:09:07.088 +01:00 [INF] Got dns-01 challenge https://acme-v02.api.letsencrypt.org/acme/chall-v3/9708567618/-lOi5g
2021-01-03 14:09:08.288 +01:00 [INF] Got http-01 challenge https://acme-v02.api.letsencrypt.org/acme/chall-v3/9788369084/rrpU7A
2021-01-03 14:09:08.869 +01:00 [INF] Got dns-01 challenge https://acme-v02.api.letsencrypt.org/acme/chall-v3/9788369084/I7A3_g
2021-01-03 14:09:08.870 +01:00 [INF] Attempting Domain Validation: cinbalans.nl
2021-01-03 14:09:08.870 +01:00 [INF] Registering and Validating cinbalans.nl
2021-01-03 14:09:08.870 +01:00 [INF] Performing automated challenge responses (cinbalans.nl)
2021-01-03 14:09:08.873 +01:00 [INF] Preparing challenge response for the issuing Certificate Authority to check at: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs with content 1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs.SG2UB9a9dlembOWOVjUJBbf6TE42r6brpHzO8I0QSH0
2021-01-03 14:09:08.873 +01:00 [INF] If the challenge response file is not accessible at this exact URL the validation will fail and a certificate will not be issued.
2021-01-03 14:09:08.917 +01:00 [INF] Using website path C:\Websites\www.cinbalans.nl
2021-01-03 14:09:08.918 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:09.997 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:09.997 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:10.002 +01:00 [ERR] Failed to confirm URL is accessible : http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs
System.Net.WebException: Cannot handle redirect from HTTP/HTTPS protocols to other dissimilar ones. ---> System.UriFormatException: Invalid URI: The hostname could not be parsed.
at System.Uri.CreateThis(String uri, Boolean dontEscape, UriKind uriKind)
at System.Uri.CreateUri(Uri baseUri, String relativeUri, Boolean dontEscape)
at System.Net.HttpWebRequest.CheckResubmit(Exception& e, Boolean& disableUpload)
--- End of inner exception stack trace ---
at System.Net.HttpWebRequest.EndGetResponse(IAsyncResult asyncResult)
at System.Threading.Tasks.TaskFactory`1.FromAsyncCoreLogic(IAsyncResult iar, Func`2 endFunction, Action`1 endAction, Task`1 promise, Boolean requiresSynchronization)
--- End of stack trace from previous location where exception was thrown ---
at Certify.Management.NetworkUtils.<CheckURL>d__4.MoveNext() in C:\Work\GIT\certify_dev\certify\src\Certify.Shared\Management\NetworkUtils.cs:line 153
2021-01-03 14:09:10.068 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:11.279 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:11.279 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:11.514 +01:00 [ERR] Failed to confirm URL is accessible : http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs
2021-01-03 14:09:11.516 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:12.783 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:12.783 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:12.783 +01:00 [ERR] Failed to confirm URL is accessible : http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs
2021-01-03 14:09:12.785 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:13.882 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:13.882 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:13.883 +01:00 [ERR] Failed to confirm URL is accessible : http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs
2021-01-03 14:09:13.885 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:15.041 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:15.041 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:15.042 +01:00 [ERR] Failed to confirm URL is accessible : http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs
2021-01-03 14:09:15.044 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:20.555 +01:00 [INF] (proxy api) URL is not accessible. Result: [404] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:20.555 +01:00 [INF] Checking URL is accessible: http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:21.539 +01:00 [ERR] Failed to confirm URL is accessible : http://cinbalans.nl/.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs
2021-01-03 14:09:21.541 +01:00 [INF] Requesting Validation: cinbalans.nl
2021-01-03 14:09:21.541 +01:00 [INF] Attempting Domain Validation: www.cinbalans.nl
2021-01-03 14:09:21.541 +01:00 [INF] Registering and Validating www.cinbalans.nl
2021-01-03 14:09:21.542 +01:00 [INF] Performing automated challenge responses (www.cinbalans.nl)
2021-01-03 14:09:21.543 +01:00 [INF] Preparing challenge response for the issuing Certificate Authority to check at: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM with content 7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM.SG2UB9a9dlembOWOVjUJBbf6TE42r6brpHzO8I0QSH0
2021-01-03 14:09:21.543 +01:00 [INF] If the challenge response file is not accessible at this exact URL the validation will fail and a certificate will not be issued.
2021-01-03 14:09:21.568 +01:00 [INF] Using website path C:\Websites\www.cinbalans.nl
2021-01-03 14:09:21.568 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:23.608 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:23.608 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:23.612 +01:00 [ERR] Failed to confirm URL is accessible : http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM
2021-01-03 14:09:23.614 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:24.754 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:24.754 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:25.071 +01:00 [ERR] Failed to confirm URL is accessible : http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM
2021-01-03 14:09:25.074 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:26.221 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:26.221 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:26.221 +01:00 [ERR] Failed to confirm URL is accessible : http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM
2021-01-03 14:09:26.225 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:27.319 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:27.320 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:27.328 +01:00 [ERR] Failed to confirm URL is accessible : http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM
2021-01-03 14:09:27.330 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:28.670 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:28.670 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:28.675 +01:00 [ERR] Failed to confirm URL is accessible : http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM
2021-01-03 14:09:28.676 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: True, timeout: 5000ms]
2021-01-03 14:09:29.948 +01:00 [INF] (proxy api) URL is not accessible. Result: [301] Resource not accessible, Timeout or Redirected
2021-01-03 14:09:29.948 +01:00 [INF] Checking URL is accessible: http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM [proxyAPI: False, timeout: 5000ms]
2021-01-03 14:09:29.955 +01:00 [ERR] Failed to confirm URL is accessible : http://www.cinbalans.nl/.well-known/acme-challenge/7FaVbUwJnVRuyhLBhQGHBRTQBRj7ca6Y1H-u7TEDIiM
2021-01-03 14:09:29.955 +01:00 [INF] Requesting Validation: www.cinbalans.nl
2021-01-03 14:09:29.971 +01:00 [INF] Attempting Challenge Response Validation for Domain: cinbalans.nl
2021-01-03 14:09:29.972 +01:00 [INF] Registering and Validating cinbalans.nl
2021-01-03 14:09:29.972 +01:00 [INF] Checking automated challenge response for Domain: cinbalans.nl
2021-01-03 14:09:30.492 +01:00 [WRN] Challenge response validation still pending. Re-checking [10]..
2021-01-03 14:09:32.417 +01:00 [INF] Fetching https:///.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs: Invalid empty hostname in redirect target
2021-01-03 14:09:37.838 +01:00 [INF] Validation of the required challenges did not complete successfully. Fetching https:///.well-known/acme-challenge/1U6SS-DUqx8R662fFcRJEc6R400CF4BCMlmi_AbOPUs: Invalid empty hostname in redirect target
2021-01-03 14:43:32.179 +01:00 [INF] Previous renewals failed: 3. Renewal will be attempted within 48hrs.
Hope anyone can help me.
BR,
Kenneth
