Is there a way, or plans in the future, to be able to automate joining the CCM to the Management Hub?
When installing the client to servers, it’s annoyingly tedious to have login to the UI of the server just to point it at the Management Hub URL and provide client ID/secret.
We need to update our CCM CLI docs but from the hub docs we have this:
certify hub join <url of mgmt hub API> <client id> <client secret>
As an aside note that licensed customers are recommended to send support questions to support at certifytheweb.com rather than posting to the community forum as official helpdesk support is generally quicker.
“As an aside note that licensed customers are recommended to send support questions”
Yeah… but now I found the answer without opening a ticket… which is the POINT of having a community… eventually you’ll get enough people here answering questions that you won’t have to answer every one of them yourself.
P.S. crazy cool tool!
P.P.S. a way to push updates from the Hub would be great too…
Sure, and it’s in the docs now so you don’t need do sift through the community posts, but if you use support you get priority replies and can include private things like affected domains etc. My point was more that they are entitled to pirority support.
This is frequently requested, the details of how to do without relying on having administrative access to every installation are a little complex. We haven’t ruled it out but it may end up being a choice between enabling that feature and having good security practices (minimal privileges), which isn’t great. It’s even trickier on linux than on windows because our default stance on Windows is Local System (!) and on linux it’s a dedicated user account that starts with no permissions.
In the meantime we suggest using Ansible Update with Ansible | Certify The Web Docs although anyone with many servers probably has their own favorite deployment tool already.
Very interested in suggestions, but we may not be able to do a one size fits all approach to updates.
