I’m having problems getting CtW pushing a staging cert into an AZ KeyVault. it’s been permissioned as a Key Vault Certificates Officer and is being accessed from a CtW instance running on a VM in the same Subcription as the Keystore.
PS C:\Users\steved> $azurePassword = ConvertTo-SecureString "<secret>" -AsPlainText -Force
PS C:\Users\steved> $credentials = New-Object Microsoft.Azure.Commands.ActiveDirectory.PSADPasswordCredential -Property @{ StartDate=Get-Date; EndDate=Get-Date -Year 2024; Password=$azurePassword}
PS C:\Users\steved> $MyServicePrincipal = New-AzADServicePrincipal -DisplayName "Certify The Web" -PasswordCredential $credentials
WARNING: Upcoming breaking changes in the cmdlet 'New-AzADServicePrincipal' :
- The output type is changing from the existing type :'Microsoft.Azure.Commands.ActiveDirectory.PSADServicePrincipal' to the new type :'Microsoft.Azure.PowerShell.Cmdlets.Resources.MSGraph.Models.ApiV10.IMicrosoftGraphServicePrincipal'
- The output type is changing from the existing type :'Microsoft.Azure.Commands.Resources.Models.Authorization.PSADServicePrincipalWrapper' to the new type :'Microsoft.Azure.PowerShell.Cmdlets.Resources.MSGraph.Models.ApiV10.IMicrosoftGraphServicePrincipal'
Note : Go to https://aka.ms/azps-changewarnings for steps to suppress this breaking change warning, and other information on breaking changes in Azure PowerShell.
WARNING: 12:46:00 - New-AzAdServicePrincipal will no longer assign role 'Contributor' to new created service principal by default
PS C:\Users\steved> Get-AzADApplication | Select-Object displayname, objectid, applicationid|findstr Cert
WARNING: Upcoming breaking changes in the cmdlet 'Get-AzADApplication' :
- The output type is changing from the existing type :'Microsoft.Azure.Commands.ActiveDirectory.PSADApplication' to the new type :'Microsoft.Azure.PowerShell.Cmdlets.Resources.MSGraph.Models.ApiV10.IMicrosoftGraphApplication'
Certify The Web <ob1-id> <app-id>
PS C:\Users\steved> Get-AzSubscription -SubscriptionName "INFRA CORP"
Name Id TenantId State
INFRA CORP <ob2-id> <tenant ID> Enabled
PS C:\Users\steved>
The Task is setup as
with the credential as
I can now see the application in my az console and have permissioned it with all permission bar purge (we’re using access policies rather than RBAC, even though we assigned the “Key Vault Certificates Officer” role above)
The worrying thing is I don’t see any attempt to establish connectivity to Azure at the time the script kicks off according to the logs, all I see logged is
2021-11-08 14:01:45.819 +00:00 [INF] ---- Beginning Request [infra-test2.***.com] ----
2021-11-08 14:01:45.819 +00:00 [INF] Certify/5.5.7.0 (Windows; Microsoft Windows NT 10.0.14393.0)
2021-11-08 14:01:45.824 +00:00 [INF] Beginning Certificate Request Process: infra-test2.***.com using ACME Provider:Certes
2021-11-08 14:01:45.824 +00:00 [INF] Requested identifiers to include on certificate: infra-test2.***.com
2021-11-08 14:01:45.824 +00:00 [INF] Beginning certificate order for requested domains
2021-11-08 14:01:45.824 +00:00 [INF] BeginCertificateOrder: creating/retrieving order. Retries remaining:2
2021-11-08 14:01:46.125 +00:00 [INF] Created ACME Order: https://acme-staging-v02.api.letsencrypt.org/acme/order/****************
2021-11-08 14:01:46.404 +00:00 [INF] Fetching Authorizations.
2021-11-08 14:01:47.531 +00:00 [INF] Got dns-01 challenge https://acme-staging-v02.api.letsencrypt.org/acme/chall-v3/*************************
2021-11-08 14:01:47.532 +00:00 [INF] Order authorizations already completed.
2021-11-08 14:01:47.543 +00:00 [INF] Requesting Certificate via Certificate Authority
2021-11-08 14:01:51.391 +00:00 [INF] Completed Certificate Request.
2021-11-08 14:01:51.419 +00:00 [INF] Performing Automated Certificate Binding
2021-11-08 14:01:52.472 +00:00 [INF] Completed certificate request and automated bindings update (IIS)
2021-11-08 14:01:52.899 +00:00 [INF] Request completed
2021-11-08 14:01:52.900 +00:00 [INF] Performing Post-Request (Deployment) Tasks..
2021-11-08 14:01:52.910 +00:00 [INF] Task [Export Certificate] :: Task is enabled and primary request was successful.
2021-11-08 14:01:52.910 +00:00 [INF] Export Certificate: Copying file (Windows file copy) to c:\users\dunnea\Documents\le-infra-test2.pfx
2021-11-08 14:01:52.911 +00:00 [INF] File Copy completed: c:\users\dunnea\Documents\le-infra-test2.pfx
2021-11-08 14:01:52.911 +00:00 [INF] Task [Deploy to Azure Key Vault] :: Task is enabled and primary request was successful.
2021-11-08 14:03:22.618 +00:00 [ERR] Failed to deploy certificate [InfraTest2] to Azure Key Vault :System.AggregateException: Retry failed after 4 tries. Retry settings can be adjusted in ClientOptions.Retry. ---> Azure.RequestFailedException: Unable to connect to the remote server
at Azure.Core.Pipeline.HttpWebRequestTransport.<ProcessInternal>d__7.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
at Azure.Core.Pipeline.HttpWebRequestTransport.<ProcessAsync>d__6.MoveNext()
at Azure.Core.Pipeline.ResponseBodyPolicy.<ProcessAsync>d__5.MoveNext()
at Azure.Core.Pipeline.BearerTokenAuthenticationPolicy.<ProcessAsync>d__11.MoveNext()
at Azure.Core.Pipeline.RedirectPolicy.<ProcessAsync>d__5.MoveNext()
at Azure.Core.Pipeline.RetryPolicy.<ProcessAsync>d__11.MoveNext()
--- End of inner exception stack trace ---
at Azure.Core.Pipeline.HttpPipeline.<SendRequestAsync>d__11.MoveNext()
at Azure.Security.KeyVault.KeyVaultPipeline.<SendRequestAsync>d__29.MoveNext()
at Azure.Security.KeyVault.KeyVaultPipeline.<SendRequestAsync>d__19`2.MoveNext()
at Azure.Security.KeyVault.Certificates.CertificateClient.<ImportCertificateAsync>d__33.MoveNext()
at Plugin.DeploymentTasks.Azure.AzureKeyVault.<Execute>d__6.MoveNext()
---> (Inner Exception #0) Azure.RequestFailedException: Unable to connect to the remote server
at Azure.Core.Pipeline.RetryPolicy.<ProcessAsync>d__11.MoveNext()<---
---> (Inner Exception #1) Azure.RequestFailedException: Unable to connect to the remote server
---> (Inner Exception #2) Azure.RequestFailedException: Unable to connect to the remote server
---> (Inner Exception #3) Azure.RequestFailedException: Unable to connect to the remote server
2021-11-08 14:03:22.618 +00:00 [ERR] Key Vault Deployment Failed
2021-11-08 14:03:22.618 +00:00 [INF] Export Certificate :: Task Completed OK
2021-11-08 14:03:22.618 +00:00 [INF] Deploy to Azure Key Vault :: Key Vault Deployment Failed
2021-11-08 14:03:22.618 +00:00 [INF] Deployment Tasks did not complete successfully.
