First, thanks for the app. It was quite helpful.
I created my cert and got it installed. To check it, i immediately went to Qualys SSL Labs to check to make sure everything was OK.
It reported that “This server’s certificate chain is incomplete.” A little more testing showed that it does seem to be incomplete.
What did I do wrong? I can’t find any option to include the cert chain.
How can I fix this?
Thanks!
