Hello and thanks for this good project.
I want to translate Certify into my language.
Is it enough to translate the .resx files under the /src/Certify.Locales directory?
Thanks for your interest. To contribute a translation you would use the ResX Manager extension in visual studio, which is a tool which can coordinate all the translations together. Our UI resources are mainly defined in SR.resx. You would need to create your own fork, make your changes then submit a PR via github.
We are currently working on a new cross-platform UI which will likely be released later this year or next year so you may want to hold off contributing translations until then.
I have completed the translation but I want to test it before PR.
I tried building Certify on my local computer but I am getting many errors.
I couldn’t find a guide for build the source code. Can you share?
Hi, this is all more a discussion for Issues · webprofusion/certify · GitHub but I’ve committed a couple of updates that were still hanging around on my machine, perhaps that was stopping you. The standard way you should be able to build would be:
Ensure you have Visual Studio 2022, .net 4.6.2 build target and .net 6 build targets/sdks installed
- Clone the repo (development branch)
- Open Certify.Core.Service.sln in VS, build and run (in Debug, not Release)
- with service still open and running, Open Certify.UI.sln, build and run
If you have the current code, what errors are you seeing?
Hello,
Thank you for the information you provided.
I submitted a PR without testing. I’ll try again as you describe and let you know.
Thanks very much for your contributed translation, it’s very much appreciated. It will be included in the next release.
Open source contributors can also request a free license key by creating a user account on https://certifytheweb.com then emailing support at certifytheweb.com with your account email.
