I have been trying to find out how to install Certify the Web via powershell and then also perform Contact Registration and Request of the first certificate using powershell.
Is that at all possible?
If not, would those functions be anywhere on the road map?
Loving your product
Karl
Hi Karl,
Thanks, yes it’s possible to install the app via powershell using our chocolatey package (there is also a winget package but we don’t maintain that directly, MS do).
If you have a look at Command Line (CLI) | Certify The Web Docs you can add a new managed certificate and perform the renewal, however we don’t have a command to perform the first contact registration with the CA of your choice, so that’s something we’d need to add. It’s a great idea so we’ll add it to the list.
