I’m new at this and was happy to get my first domain and certificate working with the guides. The first domain is just a domain.com certificate and worked great. I tried a second domain with a wildcard certificate *.domain2.com and setup the Deployment task of Deploy to CCS (exactly like the first one) and it runs without error. However, when I go to the folder it’s supposed to deploy to there is no new certificate. Is there a log file or something that I can look into this with?
I found the log files in %ProgramData%\Certify\logs when looking at the cert instance log file it has errors (not sure why GUI says no errors) but it says: [ERR] Failed to copy to destination file: \server\certficates_.domain2.com.pfx:The network name cannot be found.
I think the error is b/c “_.filename.com.pfx” wouldn’t be a valid file name in windows?
Stupid type-o, I misspelled certificates in my path. Once I added the missing " i " to the path everything worked like a charm.
I don’t see a way to delete this post but feel free to.
Hi, thanks for raising this, it seems like we need a little extra validation to ensure the path has the required separators, we should also error the task if the file copy fails.
