Hi , I’ve very new to certify the web and have the following scenario
I have a server which currently doesn’t have a certificate installed for a specific wildcard domain and has an existing binding in IIS. This wildcard certificate exists in Digicert and has more than a year left in its current renewal cycle. Ideally what I want it to do is download the certificate and bind it then when a new certificate is available ( created manually via the digicert portal ) it should download / rebind the new cert before expiration - is this possible ? I can install the existing cert if needed but would really like to get an automated way to renew the cert from Digicert when it’s due.
Note I have played with Let’s Encrypt however the business would like to continue to use Digicert.
The following steps have been completed.
I’ve created an ACME URL in Digicert and have the KID / HMAC account and I’ve created a new cert authority successfully in CTW.
Each time I attempt to request a certificate the process failes with a Failed to finalise certificate order. Final order status was Processing. In digicert I see a pending request has been completed but appears to be for a new certificate which I obviously don’t want to proceed with so I reject the order.
My question is how do I get CTW to just download the certificate and renew it when it’s due - The renewal process on Digicerts side I would just use the normal process to purchase a new cert when it’s due so I don’t want that bit automated anyway.
Ideally I’d be deploying this process to lots of servers for the single wildcard - albeit with a different common name per server. I just want it to renew the cert when it’s due really I guess not order another one.
I’ve also been playing with the POSH ACME client but getting an error requesting a new certificate that way as well using New-PACertificate
WARNING: ACME response body was not JSON parseable
The remote server returned an error: (405) Method Not Allowed.
