Hi I want to use DNS-01 to authorise a certificate for a domain. Your doc says ’ You will be prompted to create a CNAME pointing to the TXT record hosted by the Certify DNS service. If you miss this prompt check back in the log file for your managed certificate (see the Status tab).
- Once you have created your CNAME record, delete any existing _acme-challenge TXT record in the same zone to avoid confusion.’
but in my case, no prompt appeared even though I requested DNS-01 under ‘authentication’. It seems to ignore me and use http anyway.
How do I make it work properly please? my credentials were created successfully using the appropriate license key in my account
