Our SimpleDNS api provider was user contributed and as such I don’t have a test server for this however I’ve downloaded a test copy and had a look at the UI, the configuration required appears to be quite specific (not the default):
The current provider code expects to construct the API call as `https://ip:port/v2/ so you need:
https setup for your API.
Options > HTTP API > Enable the HTTP API v.1 (this changes the v2 API to the subpath /v2/)
That said, in my tests I have been unable to get the API integration to work and I will now have to consider whether we will attempt to fix it or remove it completely. As a workaround I recommend either using http validation instead of DNS, or switching DNS provider (such as cloudflare or route53), or try acme-dns (which currently requires setting up your own acme-dns server).
If you need anyone for beta testing please let me know. I am more then willing to.
I would love the functionality to be fixed and continued to be support. SimpleDNS is an amazing product.
Well I will give it a try and see if I can get it to work with the software. I’m somewhat familiar with the SimpleDNS API because I am using it in a couple of our internal applications to make DNS changes on the fly and without user interaction.
Thanks, other point I missed was you need to set authentication to basic. The main problems I found were the zone results are not populated properly (although you can just type your zone name) and domains with 2 tld levels don’t work (like .co.uk)
Hi, really like/want/need this to work. Have figured it all out now and got it working. Am really stuck on the 2 tld issue. Have tested with a 1 tld and works perfectly. I have a dev team here, so will happily tweak that code block to resolve that bug if you are happy with that?
Hi, I wasn’t actually aware this was still a problem - forums are awful bug trackers (we have GitHub issues).
If you have an urgent requirement for a certificate you can:
-temporarily switch to the manual DNS update method
or use the default acme-dns service
or switch to a better supported DNS provider like away route 53 or CloudFlare.
I’m assuming this is not urgent (as in needs resolves today) as Let’s Encrypt just broke 26 million certs and I have my hands full. You can definitely try building the code from GitHub - the usual fix for tld levels is to use the base DNS provider class which has a common method for tld traversal.
Regarding the 2 tld issue, I’ve prepared an experimental fix for this in v5 (which now also includes many more DNS providers courtesy of the Posh-ACME project), I’m hoping to get to a beta release for users to test with during April.
