I’m using windows server 2012 r2 and exchange 2016.
Installed the app, set it up for exchange and everything is working fine, the cert is downloaded and applied but I get this errors
2020-06-16 11:01:11.780 +02:00 [INF] Performing Post-Request (Deployment) Tasks..
2020-06-16 11:01:11.781 +02:00 [INF] Task [Deploy to Exchange] :: Task is enabled and primary request was successful.
2020-06-16 11:01:11.791 +02:00 [INF] Executing command via PowerShell
2020-06-16 11:01:23.357 +02:00 [ERR] Write-Host: A command that prompts the user failed because the host program or the command type does not support user interaction. Try a host program that supports user interaction, such as the Windows PowerShell Console or Windows PowerShell ISE, and remove prompt-related commands from command types that do not support user interaction, such as Windows PowerShell workflows.
At line:13 char:1
+ Write-Host "Enabling Certificate for Exchange services.."
At line:18 char:1
+ Write-Host "Certificate set OK for services."
2020-06-16 11:01:23.357 +02:00 [INF] Deploy to Exchange :: Write-Host: A command that prompts the user failed because the host program or the command type does not support user interaction. Try a host program that supports user interaction, such as the Windows PowerShell Console or Windows PowerShell ISE, and remove prompt-related commands from command types that do not support user interaction, such as Windows PowerShell workflows.
At line:13 char:1
At line:18 char:1
2020-06-16 11:01:23.358 +02:00 [INF] Deployment Tasks did not complete successfully.
Can anyone help?
Thanks.
