Hi all, first post - Noob to most things and have an old server I’m training myself with running Server 2016 and Exchange 2016. I’ve just tried Certify and whilst it grabs the certs no problem, the Exchange script however fails with the below.
Any ideas?!
Thanks!
Error - ActionPreferenceStopException: The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: A special Rpc error occurs on server STEXCH01: The certificate with thumbprint xxxxxxxxxxxx was not found.
EDIT: I fixed it! I had ‘no deployment’ set. Changed to Certificate Store Only and all is good. Thanks anyway!
