I am using the post script example for creating a JKS but it always shows as error even when it has actually completed. It appears the PowerShell comments are being output as errors when they shouldn’t be. Am I missing something?
The .ps1 script being run:
param($result)
keytool -importkeystore -srckeystore $result.ManagedItem.CertificatePath -srcstoretype pkcs12 -destkeystore C:\Users\name\Documents\fsa-keystore.jks -deststoretype pkcs12 -deststorepass password -srcstorepass password
And the error log as you can see which is actually a success:
2023-07-10 18:49:06.498 +01:00 [INF] ---- Performing Task [On-Demand or Manual Execution] :: Create Javascript Keystore ----
2023-07-10 18:49:06.498 +01:00 [INF] Task [Create Javascript Keystore] :: Task will run for any status
2023-07-10 18:49:06.499 +01:00 [INF] Executing command via PowerShell
2023-07-10 18:49:07.698 +01:00 [ERR] Powershell Task Completed.Error: keytool.exe: Importing keystore C:\ProgramData\certify\assets\server.acropolis-aviation.com\20231008_f6bf4a34.pfx to C:\Users\name\Documents\fsa-keystore.jks...
At C:\Users\name\Documents\CreateJKS.ps1:5 char:1
+ keytool -importkeystore -srckeystore $result.ManagedItem.CertificateP ...
Error: keytool.exe: Entry for alias server.acropolis-aviation.com [certify] 7/10/2023 5:01:58 pm to 10/8/2023 5:01:57 pm successfully imported.
Error: keytool.exe: Import command completed: 1 entries successfully imported, 0 entries failed or cancelled
How can I stop this from happening so I get a success message?
