GoDaddy DNS API issue
Hello everyone,
I set up dns-01 check with GoDaddy DNS API credentials. However, when I try to set up a domain for certificate auto-renewal and choose the GoDaddy DNS API credentials, it just shows “Select Zone” in the dropdown. Am I missing something? I haven’t input any text records into any domains, not sure if I’m supposed to.
When I test the credentials, I get a small wheel spinning for a second, and then nothing, no status message or anything.
Thanks for any guidance you may be able to provide.
For GoDaddy users they only allow their API to be used by customers with 10 or more domains, most likely that’s the issue. You can test the credentials under Settings > Stored Credentials [Test]
