I’m having a bit of trouble with the GoDaddy DNS API
It’s okay with TLD like .c o m, .n e t, .o r g, etc.
But as soon as I use a SLD like c o.u k, o r g.u k it always fails with this type of message:
GoDaddy DNS API :: Could not add dns record _acme-challenge-test.example to zone co.uk Result: Forbidden - {“code”: Access_Denied",message":“Authenticated user is not allowed access”}
My domain match and zone-id are set correctly but I’m assuming because its trying to add to to the zone CO .UK which isn’t correct this is why its failing.
I’m currently using a custom script but it would be nice to just rely on the API.
Note: TLD spacing is delebrate as the forum won’t allow more than two URL
Thanks, can you email through full details and a log file to support {at} certifytheweb.com? I assume you’re not actually trying to get a cert for the ‘.co.uk’ domain.
I can confirm this a bug, caused by incorrect domain name traversal. Most of our other providers match on a zone id (usually a domain or identifier), this one (and the SimpleDNS provider) uses the alternative method of trying to match the zone by finding the zone with the most specific match for the domain. Unfortunately the logic is wrong. Fix in next update.
