Hi. I have tried setting up a wildcard certificate with DNS challenge for my domain, hosted on GoDaddy dns. I have successfully obtained an api key for GoDaddy, and used the credentials in the Authorization settings. It is populating my domain name into the Zone ID section, so I assume the api key is working ok. When I do a test it is returning an error
BlockquoteGoDaddy DNS API :: Could not add dns record _acme-challenge-test to zone “mydomainhere” Result: 422 - {“code”:“INVALID_BODY”,“fields”:[{“code”:“MISMATCH_FORMAT”,“message”:“does not conform to the ‘domain’ format, based on pattern: /[1]{1,63}(\.[^.]{1,63})+$/”,“path”:“path.domain”}],“message”:“Request body doesn’t fulfill schema, see details in
fields”}
My domain is a subdomain of .gov.au and I’m wondering if its a non standard domain name issue. I have changed it to manual and successfully added the TXT fields to my dns zone and got it working that way, but i would like it to be able to work automatically. Anyone have any ideas?
Thanks in advance.
