Help to find password for .pfx certificate
We use certify the web to generate .pfx certificates. When we set this up a few years ago, I don’t recall using a password. Is there a way for me to find out what password I used or if I even used one? I understand that .pfx files usually are protected by a password. thanks
Hi, the default password is blank, you can set one under Certificate > Advanced > Signing & Security but you then need to re-request the certificate to rebuild the PFX.
