I’m trying to setup for our windows servers to use Lets Encrypt, I’ve already been able to do this using the same method on our linux servers using certbot.
The keyfile is created against the same service account that is working currently for certbot.
I get the following when I hit test
Powershell/PoshACME DNS :: Error - RuntimeException: Unsupported RSA key size. Must be 2048-4096 in 8 bit increments.
at System.Management.Automation.Runspaces.AsyncResult.EndInvoke()
at System.Management.Automation.PowerShell.EndInvoke(IAsyncResult asyncResult)
at Certify.Management.PowerShellManager.InvokePowershell(CertificateRequestResult result, String executionPolicy, String scriptFile, Dictionary`2 parameters, String scriptContent, PowerShell shell) in C:\Work\GIT\certify_5.0.x\certify\src\Certify.Shared.Compat\PowerShellManager.cs:line 182
at Certify.Management.PowerShellManager.d__0.MoveNext() in C:\Work\GIT\certify_5.0.x\certify\src\Certify.Shared.Compat\PowerShellManager.cs:line 90
I am unable to find where I can configure this keysize option, anyone else been able to use Google Cloud DNS? Client version is 5.0.12.0.
I was able to create a cert using manual dns, naturally I don’t want to have that as the deployed option
I’ve recently been testing Google Cloud DNS for another issue and can confirm that it does work but there may be an environmental or configuration reason it’s not working for you. Can you try out this test update to see if the issue still occurs: Version 5.1.0 (Release Candidate) testing
As part of the conversation with Google Cloud it uses a Json Web Signature and in Posh-ACME this is expected to be an RSA key. The normal generated Google key is fine but did you upload a custom key?
I encountered this today as well - it seems that for whatever reason, the GCP console’s JSON file can generate files which trigger this error. I had tried toggling the CRLF and it didn’t work with the invalid key. I just regenerated a key in the console and that worked fine.
