I downloaded and installed your app
I think I registered a certificate, it requested I put in a TXT record in my DNS records (which I did) it all came up in green and it’s listed under the managed certificates
but where do I get the TLS cert and key so I can import it into AWS and OKTA?
Hi, the app is mainly aimed at using the certificates on your server in Windows but you can do anything you like with the certificate once you have it. If you check ‘Show Advanced Options’ and go to the Other Options tab you’ll see the PFX file path. As the certificates need to be renewed regularly you would probably want to write a ‘post-request’ script to do custom deployment in this case (converting to other formats, copying or deploying etc), see https://docs.certifytheweb.com/docs/script-hooks.html#script-basics
That said, if you’re already using AWS they do also offer a certificates service.
