Hello. I use simple web hosting and I try to issue certificate with http-01 verification.
The problem is that I do not have a pause to upload files to remote hosting folder to perform checks.
Can you please add a delay to software options to have a possibility to upload files to hosting before checks (like in dns verification)?
Thanks, this feature is on the list of things to-do but for now I would recommend trying a different tool. Certbot on windows can do manual http challenges.
Another alternative is to use Cloudflare (free) in front of your site (as a DNS proxy, the default function of cloudflare), they will in turn enable https and put a certificate on it, so you then don’t need to do anything on your site.
