I am trying out the Management Hub alpha, but hitting a roadblock configuring an ACME CA account. We use Sectigo Enterprise, and our config requires a external account. The ability to provide a Key ID and Key (HMAC) is available in the Certify Certificate Manager in the Advanced tab of the Edit ACME Account, but this seems to be completely missing from the Management Hub. Is it somewhere else and I am just missing it? Is it configurable in a .json somewhere?
Thanks for your feedback, yes are correct - the ability to provide EAB credentials as not et been enabled in that UI. We’ll get that added and do a release next week.
Which method/platform are you trying it out on?
If you’re on Windows it’s possible as a workaround to use Certify Certificate Manager (the v7 alpha version) to edit that on the same machine, because they write to the same configuration.
Forgot to say that EAB etc was added a while back.
