我没有启用IIS 用fastapi服务 怎么设置
For nginx support see Using with Apache, nginx or Other Web Servers | Certify The Web Docs
You will need a Deployment Task to export the certificate files for nginx to use and you will need to manually edit your configure to use the certificate files.
When renewing you may also want to restart the nginx service so it picks up the latest files.
