Hello, I am a newbie and I see that I can create a new request for certificates.
But I also want to import my already created certificates to see all of them in one place. So when renewal time approaches I may have the change to renew them from certifytheweb console. Can I import my already created certificates into the tool. Thanks in advance.
Regards.
The app can see some some information from certain other certificate managers (if external certificate managers is enabled under settings) but it doesn’t manage existing manually installed certs.
Managed certificates require at least a configuration to tell the app how the certificate will be renewed (http or DNS validation). You can however setup your new managed certificate in advanced but set the Deployment Mode under the Depolyment Tab to None, that way you know you can get a certificate ok but it won’t be used yet.
