Have had three certificates working fine, but the other day all three returned with
Powershell/PoshACME DNS :: Error: Unable to connect to the remote server at Get-SimplyTXTRecord, C:\Program Files\CertifyTheWeb\Scripts\DNS\PoshACME\Plugins\Simply.ps1: line 225
at Add-DnsTxt, C:\Program Files\CertifyTheWeb\Scripts\DNS\PoshACME\Plugins\Simply.ps1: line 29
at <ScriptBlock>, <No file>: line 33
I’ve looked at the script and https://api.simply.com/2/ is up-and-running, so I’m a bit lost as to what the issue is. Anyone experienced this?
This could affect communication if your server doesn’t have TLS1.2 enabled (or if a common cipher can’t be found). I’d only expect to see that on Server 2012 or lower though, which version of Windows are you using?
