In the documentation, it is decribed that to use a managed challenge with Certify Certificate Manager you have to “select dns-01 as the Challenge Type, and Certify Managed Challenge API as the provider.”
I don’t find that provider?
Just noticed that the CCM docs specifically mentions v7+, and we are running 6.1.11 which seems to be latest release.
Guess documentation is about upcoming v7.
When is that scheduled to be released? I am investigating CCM and Management Hub for a customer aiming to automate and centralize certificate handling
We are working on one more significant feature then we plan to make the next release the production versions.
The upcoming feature is to be able to subscribe to the hub for specific managed certificate from an instance, that way the instance only has to deploy the cert but doesn’t have to perform the renewal itself.
We also want to simplify managed challenges from an instance so that certain instances can be allowed to use specific managed challenges without configuring a specific API credentials, they just have to be joined to the hub.
That sounds great! Do you have a timeframe or guesstimate on when we can go on with our test?
We don’t have a specific date but the intention is to complete that work as soon as possible allowing for sufficient testing.
Our hope is that the release is this month, however you should resume evaluation in general in the meantime. You can still evaluate managed challenges if you use v7 on a test server or a light workload production server.
Thanks.
I have joined CCM to the HUB, and use a stored credential with API ID and secret.
Error:
Certify Managed Challenge API :: Update failed [Unauthorized]: X-Client-ID or X-Client-Secret HTTP header missing in request
I just noticed that my question is a duplicate of another users. But I am not sure i understand the answer to that.
I followed the “Combined Hub joining and Managed Challenge Key” section of the docs - is that not possible yet?
Yeah, I’m not sure why it works fine for me (and at least some other users) but not for others. Either way the new version should hopefully be out next week subject to testing and it has a simplified method for managed challenge authentication via the joined instance.
If you haven’t already done so, start with a new managed certificate rather than modifying an existing one, as there could be issues with stale config being carried over if you just modify an existing DNS challenge to be a managed challenge.
I created a new managed certificate, same error unfortunately.
I’ll wait for the new update.
