What to run a Post-request script in Verison 5.0.12.0
All documentation says to check the box for Show Advanced options.
There is No Checkbox? Did it get moved or just removed in the current version. If so does someone have a download link to an older version of Certify?
Thanks,
Post request scripts can be added in the Deployment tab on the right, Deployment Tasks sub-tab in the center.
Thank you I have been trying to find this all afternoon.
Thanks,
If I were to make a guess based on my own experiences rather than documentation(sorry, I havenât read much of it)⌠I would say that itâs not obvious enough when there are sub-tabs in the center. Not all pages have sub-tabs and visually itâs easy to over look when you donât know they exist until you enter that page.
I donât know what control makes the icons on the right to switch views⌠but if itâs possible to show sub-entries there, to directly jump to those pages, it would be very hard to overlook them existing. If itâs possible but too ugly, maybe have the âadvancedâ checkbox again to show the ugly version with the sub-page links.
Thanks, yes itâs pretty hard to balance between trying to make options discoverable and not crowd the UI with too much stuff. Deployment Tasks in particular went through many different UI layouts. Ideally no-one would ever have to read the docs (then I wouldnât have to write any!).
Perhaps we need to have âTasksâ side tab, before or after the Deployment Tab.
" Scripting can be used by checking
Show Advanced Options
and open the Scripting
tab."
Once I was able to find were to add scripting its working great.
Thanks,
So was able to add script for Example: update Remote Desktop Role Certificates#
But when it goes to open powershell get Access is denied.
Tried Running as Administrator and still same.
2020-06-26 12:17:05.374 -05:00 [INF] Run Powershell Script :: powershell.exe: Connecting to remote server SHRSVR.LEC911.LOCAL failed with the following error message : Access is denied. For more information, see the about_Remote_Troubleshooting Help topic.
At C:\Scripts\RDWebCert.ps1:3 char:1
- ps64 -args $result -command {
2020-06-26 12:17:05.374 -05:00 [INF] Deployment Tasks did not complete successfully.
Also get
2020-06-26 16:36:56.507 -05:00 [INF] ---- Performing Task [On-Demand or Manual Execution] :: Run Powershell Script ----
2020-06-26 16:36:56.510 -05:00 [INF] Task [Run Powershell Script] :: Task will run for any status
2020-06-26 16:36:56.510 -05:00 [INF] Executing command via PowerShell
2020-06-26 16:37:16.552 -05:00 [ERR] powershell.exe: Empty path name is not legal.
Get Access Denied if I check the Box
Pass Results as First Argumen
Get Empty path name is not legal if unchecked.
Wrap output using the Preformatted text button in the post toolbar. Or manually add ```
above and below the output. This way the forum software wonât try to interpret it and make it a mess.
Is SHRSVR.LEC911.LOCAL
a remote machine or is it the machine that Certify is running from? If itâs actually remote, then getting access denied makes sense because local users on the local machine have no permissions on a remote machine. Youâd need to impersonate a domain user or domain machine that does have permission.
As general advice, itâs best to take a step back and read the descriptions a bit more because it will save you time and frustration, happy to take suggested edits though (https://github.com/webprofusion/certify-docs/tree/master/docs)
- The same paragraph in the docs that points to Scripting under Show Advanced Options explicitly states thatâs for older 4.x versions and the sentence before that tells you to look under Deployment. Perhaps the highlighting on the 4.x instructions is throwing you off.
- The example you used specifically was for older 32-bit clients, which is why it says:
This example assumes it's starting in a 32-bit instance and switches to the 64-bit powershell to import the 64-bit RemoteDesktop module. V4.x onwards of the app is 64-bit only.
For your script, you need to run as a user who has permissions (the background service runs as Local System, which may not have the required permissions). The Deployment Task has an option for you to specify impersonation credentials. You did mention trying to run as Administrator but I donât know if you mean in the deployment task itself or just the UI.
Iâd suggest the edited version of your script would be:
param($result)
$pfxpath = $result.ManagedItem.CertificatePath
Import-Module RemoteDesktop
Set-RDCertificate -Role RDPublishing -ImportPath $pfxpath -Force
Set-RDCertificate -Role RDWebAcces -ImportPath $pfxpath -Force
Set-RDCertificate -Role RDGateway -ImportPath $pfxpath -Force
Set-RDCertificate -Role RDRedirector -ImportPath $pfxpath -Force
Note that in your case you can just try your script out in powershell by specifying a path to the certificate file to test with:
$pfxpath = "C:\path to a pfx file"
So did the Edit and get and error right away saying "Set-RDRDCertificate: A Remote Desktop Services deployment does not exist on SHRSVR.LEC911.local. This operation can be performed after creating a deployment. For information about creating a deployment, run âGet-Help New-RDVirtualDesktopDeploymentâ or âGet-Help New-RDSessionDeploymentâ.
At C:\Scripts\RDWebCert.ps1:3 char:4
- Set-RDCertificate -Role RDPublishing -ImportPath $pfxpath -Force"
Ran the Script in power shell pointing to pfx location and everything runs without issues.
I tried to run as Administrator in the Deployment Task.
Very odd that it runs fine in power shell but not when running as a Deployment Task in Certify.
Thanks for Everything very new to Certify.
Thanks,
Thanks, Iâll see if I can reproduce this today and get back to you. It seems the powershell context the deployment task is running in canât see that module for some reason.
Actually it looks like the module is imported OK but it canât see the RDS config, see also https://stefanos.cloud/blog/kb/rds-error-a-remote-desktop-services-deployment-does-not-exist-in-the-server-pool/
As a workaround you could have the script deployment task output a script (write a new script to a file with all the required file paths set) then use a scheduled task to run that as the user you require. Iâll continue to investigate.
@tshemon can you confirm which version of Windows Server this is running on and whether this was a new install of RDS or is it an existing one (already working) you are trying to apply a cert to.
This is a new Terminal Server. Running on Server 2016.
Thanks,
Tom
So Iâve tested this on Server 2019 (that took a whole day!), the issue is that the background service that runs the powershell scripts is not elevated to Administrator and I donât think itâs a good idea to change that (if anything we should be running with less permissions). This limitation specifically affects this particular method (powershell) of trying to configure RDS.
In addition I note that only 2019 onwards accepts the certificate Thumbprint as an argument so you are apparently forced to re-import the PFX thatâs already present.
Instead, you need to run the script as an elevated powershell command prompt, so the easiest way to do that is have a script that generates the final script, then have that script run as administrator as a scheduled tasks, or manually as part of your regular maintenance window:
Replace the server name for the connection broker and adjust the script as required for your configuration:
param($result)
$output ="
`$connectionBroker = 'EC2AMAZ-NH8VQT5.PROJECTBIDS.CO.UK'
`$pfxpath = '$($result.ManagedItem.CertificatePath)'
Import-PfxCertificate -FilePath `$pfxpath -CertStoreLocation Cert:\LocalMachine\My -Exportable
Set-RDCertificate -Role RDPublishing -ImportPath `$pfxpath -Force -ConnectionBroker `$connectionBroker
Set-RDCertificate -Role RDWebAccess -ImportPath `$pfxpath -Force -ConnectionBroker `$connectionBroker
Set-RDCertificate -Role RDGateway -ImportPath `$pfxpath -Force -ConnectionBroker `$connectionBroker
Set-RDCertificate -Role RDRedirector -ImportPath `$pfxpath -Force -ConnectionBroker `$connectionBroker
Set-Content -Path "C:\Scripts\RDS_latest.ps1" -Value $output
This then generates another script as output which you can run manually or a scheduled task:
$pfxpath = 'C:\ProgramData\Certify\assets\ec2amaz-nh8vqt5.projectbids.co.uk\20200929_38636102.pfx'
Import-PfxCertificate -FilePath $pfxpath -CertStoreLocation Cert:\LocalMachine\My -Exportable
Set-RDCertificate -Role RDPublishing -ImportPath $pfxpath -Force -ConnectionBroker $connectionBroker
Set-RDCertificate -Role RDWebAccess -ImportPath $pfxpath -Force -ConnectionBroker $connectionBroker
Set-RDCertificate -Role RDGateway -ImportPath $pfxpath -Force -ConnectionBroker $connectionBroker
Set-RDCertificate -Role RDRedirector -ImportPath $pfxpath -Force -ConnectionBroker $connectionBroker
Actually using the certificate that Certify acquires for you is generally out of scope for the application, although features like Deployment Tasks do help with deployment they donât provide a quick solution for every type of deployment. Unfortunately you hit a particularly troublesome example and we should remove reference to the user-submitted example in the docs as clearly there is more to it.
If there is a way to configure RDS via C#/.net without running as Administrator (elevated) instead of powershell perhaps we could provide a dedicated Deployment Task.
That works Perfect
Thank you so much for all your help.
