I have the program running on my PC and am moving to a new one and need to move the settings over. Is there a facility to do this?
If you are only running a handful of certificates it’s easier to just set them up again on the new machine. We do have a beta feature for Import/Export you could try (enabled via Settings > UI Settings), it creates a single export file you can import on the destination server. You would then need to verify that new certificates and renewals work ok on the new server.
