I’m attempting to set up a certificate with validation via DNS, using TransIP as the DNS provider (Certify Certificate Manager 6.1.0.0). When clicking the ‘Test’ button, I get an error message “TransIP DNS API :: Object reference not set to an instance of an object.”, with no further context.
The log file contains:
2024-08-09 11:39:27.106 +02:00 [INF] ---- Beginning Request [windows-test.diasoft.nl] ----
2024-08-09 11:39:27.106 +02:00 [INF] Renewal Reason: Renewal attempt is due, item has failed 5 times and renewal will be periodically attempted.
2024-08-09 11:39:27.133 +02:00 [INF] Certify/6.1.0.0 (Windows; Microsoft Windows NT 10.0.20348.0)
2024-08-09 11:39:27.841 +02:00 [INF] Beginning certificate request process: windows-test.diasoft.nl using ACME provider Anvil
2024-08-09 11:39:27.842 +02:00 [INF] The selected Certificate Authority is: Let's Encrypt
2024-08-09 11:39:27.842 +02:00 [INF] Requested identifiers to include on certificate: windows-test.diasoft.nl [dns]
2024-08-09 11:39:29.477 +02:00 [DBG] Creating/retrieving order. Attempts remaining:3
2024-08-09 11:39:30.662 +02:00 [INF] Created ACME Order: https://acme-v02.api.letsencrypt.org/acme/order/1880294796/294484894146
2024-08-09 11:39:31.822 +02:00 [DBG] Fetching Authz Challenges: https://acme-v02.api.letsencrypt.org/acme/authz-v3/387627826986
2024-08-09 11:39:32.987 +02:00 [INF] Got http-01 challenge https://acme-v02.api.letsencrypt.org/acme/chall-v3/387627826986/zETUdQ
2024-08-09 11:39:33.313 +02:00 [INF] Got dns-01 challenge https://acme-v02.api.letsencrypt.org/acme/chall-v3/387627826986/9c5Z6g
2024-08-09 11:39:34.148 +02:00 [INF] Preparing automated challenge responses for: windows-test.diasoft.nl [dns]
2024-08-09 11:39:34.156 +02:00 [INF] DNS: Creating TXT Record '_acme-challenge.windows-test.diasoft.nl' with value '_Vdc3Kry2W9u1xBY8zssCZOgo1gZxdl4liS1VZT-OR4', [windows-test.diasoft.nl] using API provider 'TransIP DNS API'
2024-08-09 11:39:34.156 +02:00 [ERR] DNS update failed: TransIP DNS API :: Object reference not set to an instance of an object.
2024-08-09 11:39:34.157 +02:00 [ERR] TransIP DNS API :: Object reference not set to an instance of an object.
If I run “certify renew id=windows-test.diasoft.nl” from the command line I get the following output:
Unhandled Exception: Certify.Client.ServiceCommsException: Internal Service Error: managedcertificates/autorenew: An internal error has occurred. If this problem happens regularly please report it to support@certifytheweb.com: Object reference not set to an instance of an object. Certify.Core at Certify.Management.RenewalManager.<>c__DisplayClass2_0.<PerformRenewAll>b__0(ManagedCertificate s) in D:\a\certify-internal\certify-internal\src\certify-build\certify\src\Certify.Core\Management\RenewalManager.cs:line 65
at System.Linq.Enumerable.WhereListIterator`1.MoveNext()
at System.Linq.Buffer`1..ctor(IEnumerable`1 source)
at System.Linq.OrderedEnumerable`1.<GetEnumerator>d__1.MoveNext()
at System.Linq.Enumerable.Count[TSource](IEnumerable`1 source, Func`2 predicate)
at Certify.Management.RenewalManager.<PerformRenewAll>d__2.MoveNext() in D:\a\certify-internal\certify-internal\src\certify-build\certify\src\Certify.Core\Management\RenewalManager.cs:line 98
--- End of stack trace from previous location where exception was thrown ---
at Certify.Management.CertifyManager.<PerformRenewAll>d__30.MoveNext() in D:\a\certify-internal\certify-internal\src\certify-build\certify\src\Certify.Core\Management\CertifyManager\CertifyManager.CertificateRequest.cs:line 83
at Certify.Service.Controllers.ManagedCertificatesController.<BeginAutoRenewal>d__13.MoveNext() in D:\a\certify-internal\certify-internal\src\certify-build\certify\src\Certify.Service\Controllers\ManagedCertificateController.cs:line 165
at System.Threading.Tasks.TaskHelpersExtensions.<CastToObject>d__1`1.MoveNext()
at System.Web.Http.Controllers.ApiControllerActionInvoker.<InvokeActionAsyncCore>d__1.MoveNext()
at System.Web.Http.Controllers.ActionFilterResult.<ExecuteAsync>d__5.MoveNext()
at System.Web.Http.Filters.AuthorizationFilterAttribute.<ExecuteAuthorizationFilterAsyncCore>d__3.MoveNext()
at System.Web.Http.Dispatcher.HttpControllerDispatcher.<SendAsync>d__15.MoveNext()
at Certify.Client.CertifyApiClient.<PostAsync>d__23.MoveNext() in D:\a\certify-internal\certify-internal\src\certify-build\certify\src\Certify.Client\CertifyApiClient.cs:line 193
at Certify.Client.CertifyApiClient.<BeginAutoRenewal>d__48.MoveNext() in D:\a\certify-internal\certify-internal\src\certify-build\certify\src\Certify.Client\CertifyApiClient.cs:line 415
at Certify.CLI.CertifyCLI.<PerformAutoRenew>d__35.MoveNext() in D:\a\certify-internal\certify-internal\src\certify-build\certify\src\Certify.CLI\CertifyCLI.ManagedCertificates.cs:line 88
at Certify.CLI.Program.<Main>d__1.MoveNext() in D:\a\certify-internal\certify-internal\src\certify-build\certify\src\Certify.CLI\Program.cs:line 63
at Certify.CLI.Program.<Main>(String[] args)
Any ideas as to what I should look at further?
