Hi there
Absolutely loving your work with CTW. I installed v4 last weekend and got to grips with automating cert renewals for my Unraid server, qBittorrent box, Plex server etc. It’s great.
To achieve the above I learnt a lot about Powershell scripting (and the limitations thereof) and was pleased to see what was lined up for v5.
One of the things I do in my post-request Powershell scripts many times is a ‘sleep’ for 5 or 10 seconds whilst the last command completes, be it shutting down qBittorrent gracefully, copying files to my Unraid NAS before restarting the Web GUI, etc etc. I see that most of my Powershell heavy lifting can be moved to the multiple tasks available in v5, which is great, but there isn’t yet the opportunity to put a ‘pause’ in between tasks without explicitly creating a task to a Powershell script which has a sleep task in it.
Can I suggest a simple ‘sleep for x seconds’ choice as an option for one of the new tasks?
Just a thought but I think many would find it useful.
As I say, keep up the great work. Looking forward to v5 hitting final release!
Simon
