Powershell error when deploying cert to RAS
I am trying to use the built-in task for Remote Access Server, but get powershell errors.
The taskuser is local administrator.
The Set-RemoteAccess command is available when i open powershell.
The in-process mode uses Powershell 7, try the Auto mode with the normal service user?
Apologies.
I was sure that it would not run under the service account (system), so I always tested with a dedicated administrator account.
It works.
