Powershell Error when deploying certs to IIS / Exchange
Currently evaluating CCM Version 7.0.18.0,
now stuck on an issue with deploying a cert to Exchange 2019 on Server 2019:
2026-05-04 15:53:06.736 +02:00 [INF] Task [Deploy to Exchange] :: Task is enabled and primary request was successful.
2026-05-04 15:53:06.736 +02:00 [INF] Executing command via PowerShell
2026-05-04 15:53:06.867 +02:00 [ERR] Powershell Task Completed.Error: Add-PSSnapIn: The term 'Add-PSSnapIn' is not recognized as a name of a cmdlet, function, script file, or executable program.
Check the spelling of the name, or if a path was included, verify that the path is correct and try again.
At line:7 char:1
+ Add-PSSnapIn Microsoft.Exchange.Management.PowerShell.E2010
Error: Enable-ExchangeCertificate: The term 'Enable-ExchangeCertificate' is not recognized as a name of a cmdlet, function, script file, or executable program.
At line:28 char:2
+     Enable-ExchangeCertificate -Thumbprint $result.ManagedItem.Certif
It looks like, the context where those PS commands are run, doesnt know those commands. But I am able to run these cmdlets manually via PS shell.
Any hint on, where to search for reason why this fails?
HI @killom we are seeing a few compatibility issues being raised recently for powershell in v7. Internally we use powershell 7.x but it seems like the recent update may have reduced compatibility and we’re looking at different strategies to resolve that with an update. It looks like we may have to resort to PS5.1 by default on windows.
In the meantime our internal script for Exchange is this one:
I would suggest using this variant with the Run a Powershell script task, and enable Launch as New Process under task parameters, that way it will use the system powershell instead of the inprocess powershell runtime we provide.
@webprofusion Thank you very much for your feedback,
is it possible to force the current version of CCM to use PS5.1 or downgrade CCM to an earlier version where this compatibility issue has not yet been introduced?
I would prefer to try one of those two options to resolve the current issue rather than apply your suggested workaround, as you workaround “does not correspond to the intended behavior of the certificate provisioning process for onprem Exchange.”
Thanks so far!
Edit:
Unfortunately there is no mention of the transition from PS5.1* to PS7.x (or reducing 7.x compatibility?) in the CCM Changelogs. Release Notes - Certify Certificate Manager - Certify The Web - ACME Certificate Management for Windows and Linux, simple free certificates for IIS and more, powered by Let's Encrypt and other ACME CAs
I tried the previous version, 7.0.17.0, but it seems the problem already existed in there?
* I was wondering, because Add-PSSnapIn cmdlet has never been ported over to PowerShell Core 6 and onward - so I guess you used PS5.1 for this in an earlier version?
Yeah we didn’t realize the scope of the PS compatibility issue. There is approximately 3-4 years of development between CCM 6.x and 7.x. 6.x has been in maintenance mode for a while and 7.x has been a large endeavor.
I have the same problem. and have copied your script.
Could you please reveal what parameters you are using, as i have tried a lot of parameter combinations and get all sorts of errors?
I am using a taskuser which is local administrator.
Are you using version 7.0.20? The default settings for the Deploy to Exchange task work.
Yes i am. Upgraded from previous versions.
So what you say is that there is no need to use the script previously uploaded by you?
I just tried the built-in task again, the only thing i change is the taskuser and which services to bind.
Error: The term Add-PSSnapin is not recognized
 and so on
Apologies.
I was sure that it would not run under the service account (system), so I only tested with a dedicated administrator account.
It works.
We have still issues with powershell scripts which are using the Exchange snap in.
The following script worked without an issue in version 6:
param($result)
Add-PSSnapin Microsoft.Exchange.Management.PowerShell.SnapIn
if($result.IsSuccess) {
  $LogPath = "C:\Scripts\Certify-The-Web-Auth-SMTP-Cert\results.log"
  try {
    $TLSCert = Get-ExchangeCertificate -Thumbprint $result.ManagedItem.CertificateThumbprintHash
    $TLSCertName = "<I>$($TLSCert.Issuer)<S>$($TLSCert.Subject)"
    Get-ReceiveConnector -Identity "Client Frontend*" | Set-ReceiveConnector -TlsCertificateName $TLSCertName
    "-------------------------------------------------------" | Add-Content -Path $LogPath
    Get-Date | Add-Content -Path $LogPath
    $result | ConvertTo-Json | Add-Content -Path $LogPath
  } catch {
    $_ | Add-Content -Path $LogPath
In version 7.0.22 the following error occurs:
2026-06-30 11:56:34.970 +02:00 [ERR] Update SMTP Certificate Name :: PowerShell Execution Mode: SystemProcess (selected Automatic, using system PowerShell process on Windows by default).
PowerShell Executable: C:\WINDOWS\System32\WindowsPowerShell\v1.0\powershell.exe
Error: Fehler beim Indexvorgang. Der Arrayindex wurde als NULL ausgewertet.
Error: In C:\Program Files\CertifyTheWeb\Service\Scripts\Internal\Script-Wrapper.ps1:168 Zeichen:13
Error: +             $wrappedArguments[$lastvar] = $_
Error: +             ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~
Error:     + CategoryInfo          : InvalidOperation: (:) [], RuntimeException
Error:     + FullyQualifiedErrorId : NullArrayIndex
Error: & : Die Benennung "C:\Scripts\Certify-The-Web-Auth-SMTP-Cert\Certify" wurde nicht als Name eines Cmdlet, einer
Error: Funktion, einer Skriptdatei oder eines ausfhrbaren Programms erkannt. ƥberprfen Sie die Schreibweise des Namens,
Error: oder ob der Pfad korrekt ist (sofern enthalten), und wiederholen Sie den Vorgang.
Error: In C:\Program Files\CertifyTheWeb\Service\Scripts\Internal\Script-Wrapper.ps1:175 Zeichen:7
Error: +     & $scriptFile @wrappedArguments
Error:     + CategoryInfo          : ObjectNotFound: (C:\Scripts\Cert...TP-Cert\Certify:String) [], ParentContainsErrorRecord
Error:    Exception
Error:     + FullyQualifiedErrorId : CommandNotFoundException
Warning: Script exited with the following ExitCode: 1
Is there something wrong on our site?
Hi Jonathan,
This is a bug caused by the combination of having to call our script wrapper (to invoke the system powershell) and that your file has spaces in the name. A fix will be included in the general release version 7.1.0 which should be released shortly.
Thank you. Renaming the script file and not using spaces fixed the issue.
Update is out now and includes a fix, thanks for raising the issue!
