Problems to refresh cert
Hello. Have latest 6.x version
Update it to lates 7.
First problem - service not registered automaicaly.
I register it by hands )
Now I cannot refresh any certs
Error is
Failed to begin cetory was not accessible: Exception not handled
some lines from session.log
2026-11-13 17:52:30.965 +03:00 [INF] Performing Certificate Request: time.vlgafc.ru [54b2a443-feea-40cd-861a-34dba21f0e99]
2026-11-13 17:52:32.795 +03:00 [WRN] Failed to send renewal status report for 54b2a443-feea-40cd-861a-34dba21f0e99: the reporting service could not be reached or did not accept the report
2026-11-13 17:52:32.795 +03:00 [WRN] 1 queued status report(s) could not be sent and were dropped.
is it possible to fix situation?
The fact you had to register it by hand implies the install simply did not work, most likely it was conflict with an open/running version of the app.
Uninstall the app from Windows so there is nothing left under C:\Program Files\CertifyTheWeb (or wherever it’s installed to). Then run the install again, you program data settings will be preserved.
