新购买Product Key更换问题
之前购买的Product Key过期很久,在https://certifytheweb.com/profile账号管理里已经
没有旧Product Key的记录
今天购买了新的Product Key, Certify The Web升级到最新版,但是我不会更换成新的Product Key
如果更换新的Product Key,之前的证书数据是否会保留
我在https://certifytheweb.com找不到任何联络方式 只能在这里留言
If a license has expired for a long time it is automatically cancelled after 180 days so that we don’t keep sending you email reminders.
To apply a new key use About > Deactivate Install… then About > Enter Key… to add your new license key. Alternatively you can delete the reg_1 file from %ProgramData\certify\ and re-open the app to remove the license.
thank you ! i got it
