Hi Sir
My server certifcation failed to renew, error information as below----->
Request failed - Failed to build certificate as PFX. Check system date/time is correct and that the issuing CA is a trusted root CA on this machine. :Certification path could not be validated. System.Exception: Failed to build certificate as PFX. Check system date/time is correct and that the issuing CA is a trusted root CA on this machine. :Certification path could not be validated.
at Certify.Providers.ACME.Certes.CertesACMEProvider.ExportFullCertPFX(String certFriendlyName, String pwd, IKey csrKey, CertificateChain certificateChain, String certId, String primaryDomainPath) in C:\Work\GIT\certify_dev\certify\src\Certify.Providers\ACME\Certes\CertesACMEProvider.cs:line 1299
at Certify.Providers.ACME.Certes.CertesACMEProvider.d__34.MoveNext() in C:\Work\GIT\certify_dev\certify\src\Certify.Providers\ACME\Certes\CertesACMEProvider.cs:line 1172
— End of stack trace from previous location where exception was thrown —
at Certify.Management.CertifyManager.d__17.MoveNext() in C:\Work\GIT\certify_dev\certify\src\Certify.Core\Management\CertifyManager\CertifyManager.CertificateRequest.cs:line 906
at Certify.Management.CertifyManager.d__16.MoveNext() in C:\Work\GIT\certify_dev\certify\src\Certify.Core\Management\CertifyManager\CertifyManager.CertificateRequest.cs:line 698
at Certify.Management.CertifyManager.d__14.MoveNext() in C:\Work\GIT\certify_dev\certify\src\Certify.Core\Management\CertifyManager\CertifyManager.CertificateRequest.cs:line 421
2021-10-28 08:33:04.014 +08:00 [INF] LiveProduction: Request failed - Failed to build certificate as PFX. Check system date/time is correct and that the issuing CA is a trusted root CA on this machine. :Certification path could not be validated. System.Exception: Failed to build certificate as PFX. Check system date/time is correct and that the issuing CA is a trusted root CA on this machine. :Certification path could not be validated.
strange thing is I installed the App under C:\Program Files\CertifyTheWeb , there’s no folder named as C:\Work\GIT, the app version is 5.2.1.0, nobody changed anything . any suggestion would be appreciated. thanks.
