I’ve been experiencing issues recently when using the Certify DNS service when renewing SSL certificates which are set to Certificate Store Only
I have deleted the certificate that I’m trying to have renewed entirely from the server (without revoking) and from Certify The Web - Then creating a new a certificate order with all domains required and all CNAME and TXT records for acme-challenge have also been removed.
Initially I thought this may of been an issue with Google Trust Services but had changed over to Let’s Encrypt and receive the same errors.
At the validation stage i shouldn’t this be requesting CNAME records to be added rather than TXT if Certify’s DNS service is in use ?
Many Thanks,
