Long time users of Certify The Web may be familiar with our renewal failure notifications and dashboard (which now has a new beta version at https://dash.certifytheweb.com for more detailed reporting).
We have recently started to develop proof of concept dashboard reporting for other popular ACME tools, where possible (if they have parse-able logging or other event storage). To that end we have developed an as-yet unreleased dashboard agent tool that can currently interpret certbot, acme.sh logs and config.
If you feel you would benefit from dashboard monitoring for your renewals and would like to try out the dashboard agent, please join the conversation here with details of which ACME clients you are using, across how many servers/sites and how many certs etc.
Our dashboard monitoring is a commercial product but we hope to accommodate all sizes of organization and to that end a free tier would make some sense, we’ll see what the interest it.
Our upcoming Certify Management Hub product also has a planned inclusion of self-hosted dashboarding, see https://certifytheweb.com/ for info. If you don’t want to post here you can email support at certifytheweb.com and we can add you as a potential beta tester.
Note that this is not an issuance monitoring tool like many others (i.e. certificate transparency monitoring), this hooks into actual renewal attempts by ACME clients, so you can see renewals failing before they become urgent and (where supported) a reason or error message, not just a list of expired/unexpired certificates.
I’m very much interesting in your upcoming product Certify Management Hub, as I need self-hosted certificate management. Does this product have the ability to execute scripts on Linux after a new certificate has been created? If so, I would volunteer to beta test.
@copystring thanks, it has the same features as our current Certify Certificate Manager, so it can copy files to linux and run a remote script over SSH etc.
You will also be able to run a Certify Certificate Manager service on any target server and have that take care of certificate renewal directly (like any traditional ACME client), but the managed certificate configuration can be managed through the Management Hub UI instead of having to remote onto each server to manage the certs with a command line etc.
I’d be very interested in testing the monitoring dashboard.
We currently deploy a range of ACME clients (certbot, acme.sh, lego, simple-acme and, of course, Certify), we manage about 10 certificates across a couple of servers (windows, linux & some stuff running in Azure).
@mflynn thanks, we didn’t get much interest in the cross-client monitoring dashboard idea in general but we have integrated much of the feature into our management hub (beta).
So that’s something you can try out, you would install the hub as your management/monitoring then install the Certify Management Agent (or Certify Certificate Manager on Windows) and configure the paths in the hub settings for each instances so it can read the config/logs for each thing on each instance.
We don’t currently have lego support but if you know roughly how it stores it’s config and logs we can go from there.
