I was referred to Certify The Web by a software vendor who needs a SSL for the program they use here locally. After an admittedly step learning curve on this, I have gone through the process to request the SSL. I am using a wildcard SSL with DNS authentication. I added the DNS challenge to my public DNS and I suppose it was OK as it started the process when I requested the certificate. I am getting the message: “Success Skipping Renewal, existing certificates are OK” under the 'in progress tab. . When I look at the Managed certificates from the main tab it shows ‘no current certificate’.
What is time line for getting the certificate? I was thinking when I saw the Success that I would have the SSL.
Thanks in advance
Guy
