It would be nice if the Powershell script task Program/Script path parameter could respect quote/doublequote in the path.
I cannot find a way to use script paths with blanks.
The latest v7 beta should allow double-quoted paths but I think all versions should also allows spaces, if not try v7:
I am using v7
Tried quotes and doublequotes, it did not work until i changed path and filename to something without blanks.
Thanks, might just be that I’m on the development version, if that’s the case the next update will support this.
