I received a configuration change notification to all my IIS sites last night which caused a high CPU on the server. This happened at around 12:39 AM on the 5th of March.
In event viewer I see the below warnings for all my sites at the same time. I maybe off the mark but was this done by CertifyTheWeb? I looked at my current SSL cert on a site and it was renewed at 11:39 PM on March 4th, a hour earlier.
Not sure if there is a delay or timezone issue there but are these releated?
SSL Certificate Settings created by an admin process for endpoint : de.example.com:443 .
When certificates renew it does update the website binding related to that certificate (at least the associated thumbprint/hash) and this also causes applicationhost.config to be touched (if if the file doesn’t actually change). You would only see an update to all websites if all of your certificates renewed.
How many sites (or domain bindings) are you running and did you setup the certificates manually or using an import?
Yes so unfortunately this is a feature of the official IIS Administration library we use, it touches applicationhost.config (with no change) which in turn causes your website to restart (if this is .net it will re-enter the Application_Start), which in turn will usually mean your web application will do some work to startup. The trick is to minimise the amount of work your application does on startup.
Yeah I’ve investigated this before, from memory I don’t even think it gets logged - I found it by attaching to w3wp.exe with a debugger and setting a breakpoint in the application start. It’s not specific to Certify - you can preproduce it by manually changing an https binding in IIS manager.
You don’t think changing out the whole cert for a binding by Certify causes an application start, regardlress if config changes are disabled for recycling?
Yes, I do think that an https binding change for your site (whether performed by Certify or manually using IIS Manage) will cause this.
I’ve not tested it recently, and this was testing for specifically for ASP.net on .Net 4.6.1, not .net core - I’ve no idea if that’s affected in the same way.
I should add, it’s not the same as an app pool recycle, it’s specifically an app restart (within the pool) and from memory I don’t think it’s logged by IIS (or it wasn’t easy to find).
