The private key could not be processed. Key should be unencrypted and in PEM format
Trying to add custom private key for certificate.
Extension of the private key is *.key,
file content starts from -----BEGIN PRIVATE KEY-----
Program shows that private key file format didn’t match, and unencrypted PEM is needed.
How can I fix this?
Thanks!
Hi, can you confirm what type of key this is (RSA or EC)? Can it be parsed OK using any PEM decoder tool? How was it generated?
Our code simply tries to parse the key file as PEM format, the main limitation is that the key file can’t be password protected. This uses the BouncyCastle OpenSssl implementation.
If you can generate keys on demand, could you supply an example key that doesn’t work? i.e. one that’s not actually private.
Key is generated by mail server, thats all i know.
Thanks for the tip about PEM decoder tool,
i’ll try to generate new private key, that matches this tool.
Example key, that doesn’t work is here
(this key is not actualy private)
Thanks, so if I run this through openssl it seems to be valid but that the original is not-quite correct base64 encoding (or rather, BouncyCastle can’t/doesn’t want to parse it):
openssl rsa -in C:\temp\key.pem -check
Which then gives me an output which works with Certify:
-----BEGIN RSA PRIVATE KEY-----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-----END RSA PRIVATE KEY-----
Which email server product is this, maybe I can investigate it a little with them?
This is Zimbra Collaboration server.
Thanks for help,
private key for mail server i’v regenerate whith mathched parameters and replace it in console of mail server.
I am going to necro this post because i ran into the same issue. None of the private keys i generate with openssl work. I would expect that a standard tool like openssl can be used for this.
openssl genpkey -algorithm RSA -out private_key.pem -pkeyopt rsa_keygen_bits:4096
creates a PKCS#8 key. more modern and recommended by openssl. unfortunately does not import.
openssl genrsa -out private_key.pem 4096
creates the classic PKCS#1 RSA key. Does not import into the app either.
Please advise how i can create a private key that is working with the application. This is a requirement. We are licensed users.
Thanks, licensed users should contact support at certifytheweb.com when they have specified requirements to discuss.
As you can see from the age of this post custom private keys are not frequently used with the app (currently) but we should definitely should extend that support.
In the meantime, to convert your key to one with an RSA header (as expected by the app currently):
openssl rsa -in private_key.pem -out rsa_privatekey.pem -traditional
[A fix will be included in the next major release, the beta for which will be available in the next few weeks]
Thank you for the information. This worked.
i was giving praise too fast. there are now problems with the created pfx using that key.
openssl pkcs12 -in star.mysite.com.pfx
Enter Import Password:
Bag Attributes
    localKeyID: 02 B5 08 14 F4 05 2D 89 E8 72 93 6C 12 ED B6 28 0B B9 BF 48
    friendlyName: *.mysite.com [Certify] 28.03.2025 10:04:39 to 26.06.2025 11:04:38
Error outputting keys and certificates
4057DAA863720000:error:0308010C:digital envelope routines:inner_evp_generic_fetch:unsupported:../crypto/evp/evp_fetch.c:386:Global default library context, Algorithm (RC2-40-CBC : 0), Properties ()
This does not look like a valid pfx and other tools and appliances like cisco Firewalls seem to have problems with this.
Will you modernize your application to use the current standards soon?
I don’t know what your app does, but when i manually request a certificate with certbot with my key and password, i get back a working pfx. So your app must somehow change the pfx returned by let’s encrypt.
Hope that helps. If you need any more information feel free to ask.
Defaults you need to be aware of:
  • The default PFX algorithms retain compatibility with older versions of Windows. These conflict with the defaults for openssl 3.0+. You can opt into modern PFX algorithms using Settings > General Settings > Enable Modern PFX Algs
  • The default PFX has a blank password, you can set this under Certificate > Advanced > Signing & Security, scroll down to password.
  • In both cases you then need to request your certificate again to rebuild the pfx.
Regarding the openssl error, this is a feature of openssl 3.0+ where they changed the default algorithms understood by pkcs12 and it differs from the default expected on Windows (where the app is typically used).
E.g. to work with an example pfx using default settings:
openssl pkcs12 -in example.pfx -legacy -passout pass: -passin pass:
Note that if your version of Windows Server is an in-place upgrade from an older version you may find PFX using Modern Algs do not function on that server. That’s why we don’t use it as the default.
Let’s Encrypt themselves return a PEM encoded cert (not a PFX), which we convert into a PFX as that’s what’s commonly used on Windows.
I’m intrigued as to why you need to specify a custom private key at all? Is there some sort of legacy hardware that doesn’t let you provide your own private key?
