Dear Certify Community
I appear to have a DNS Problem with Certify The Web.
I wanted to deploy a new Certificate but even after creating all needed DNS entries and setting the TTL to 15 minutes it still doesn’t work and I have even managed to exceed the failed authorizations limit.
This is my DNS config:
I tested the DNS-01 Connection using Let’s Debug and it gave me this:
This is my Certify Log:
2023-02-13 13:51:30.154 +01:00 [INF] ---- Beginning Request [Default Web Site] ----
2023-02-13 13:51:30.154 +01:00 [INF] Certify/5.6.8.0 (Windows; Microsoft Windows NT 10.0.20348.0)
2023-02-13 13:51:30.157 +01:00 [INF] Beginning Certificate Request Process: Default Web Site using ACME Provider:Certes
2023-02-13 13:51:30.157 +01:00 [INF] Requested identifiers to include on certificate: rdg.test.pcetera.ch
2023-02-13 13:51:30.157 +01:00 [INF] Beginning certificate order for requested domains
2023-02-13 13:51:30.157 +01:00 [INF] BeginCertificateOrder: creating/retrieving order. Retries remaining:2
2023-02-13 13:51:31.376 +01:00 [INF] Created ACME Order: https://acme-v02.api.letsencrypt.org/acme/order/962622326/164554586276
2023-02-13 13:51:31.675 +01:00 [INF] Fetching Authorizations.
2023-02-13 13:51:32.552 +01:00 [INF] Got http-01 challenge https://acme-v02.api.letsencrypt.org/acme/chall-v3/203143401296/xcH5qg
2023-02-13 13:51:32.845 +01:00 [INF] Got dns-01 challenge https://acme-v02.api.letsencrypt.org/acme/chall-v3/203143401296/g58-Pw
2023-02-13 13:51:32.845 +01:00 [INF] Attempting Domain Validation: rdg.test.pcetera.ch
2023-02-13 13:51:32.846 +01:00 [INF] Registering and Validating rdg.test.pcetera.ch
2023-02-13 13:51:32.846 +01:00 [INF] Preparing automated challenge responses (rdg.test.pcetera.ch)
2023-02-13 13:51:32.846 +01:00 [INF] DNS: Creating TXT Record '_acme-challenge.rdg.test.pcetera.ch' with value '_DBM_9-jIznDK0wFm2ULQvbsoFTlXFjTCDHXnL4AG_s', in Zone Id '' using API provider 'acme-dns DNS API'
2023-02-13 13:51:33.195 +01:00 [INF] DNS: acme-dns DNS API :: Updated: _acme-challenge.rdg.test.pcetera.ch :: ddaefb54-4f31-4b30-8360-e9b178adbe44.auth.acme-dns.io
2023-02-13 13:51:33.195 +01:00 [INF] Requesting Validation: rdg.test.pcetera.ch
2023-02-13 13:51:38.234 +01:00 [INF] Attempting Challenge Response Validation for Domain: rdg.test.pcetera.ch
2023-02-13 13:51:38.234 +01:00 [INF] Registering and Validating rdg.test.pcetera.ch
2023-02-13 13:51:38.235 +01:00 [INF] Checking automated challenge response for Domain: rdg.test.pcetera.ch
2023-02-13 13:51:39.120 +01:00 [INF] Domain validation failed: rdg.test.pcetera.ch
DNS problem: NXDOMAIN looking up TXT for _acme-challenge.rdg.test.pcetera.ch - check that a DNS record exists for this domain BadRequest urn:ietf:params:acme:error:dns
2023-02-13 13:51:41.178 +01:00 [INF] DNS: Deleting TXT Record '_acme-challenge.rdg.test.pcetera.ch', in Zone Id '' using API provider 'acme-dns DNS API'
2023-02-13 13:51:43.677 +01:00 [INF] Validation of the required challenges did not complete successfully. Domain validation failed: rdg.test.pcetera.ch
2023-02-13 13:51:43.677 +01:00 [INF] Performing Post-Request (Deployment) Tasks..
2023-02-13 13:51:43.678 +01:00 [INF] Task [Export Certificate] :: Task is enabled but will not run because primary request unsuccessful.
2023-02-13 13:51:43.678 +01:00 [INF] Export Certificate :: Task is enabled but will not run because primary request unsuccessful.
2023-02-13 13:51:43.678 +01:00 [INF] Validation of the required challenges did not complete successfully. Domain validation failed: rdg.test.pcetera.ch
Is there anything I can do to fix this?
Greetings
Martin
