Use with desec.io subdomain
Hello, I’m trying to use certifytheweb with a desec.io subdomain. Can this be done? When I saerched for it, it apaired that it could. I’m using the certify the web key, and a script that goes to desec.io. It completes and all looks good. Issues is it does nothing on the desec.io side. What might the issue be?
Can you describe more about what you have tried to do?
Are you using The DeSec DNS provider API via Posh ACME as your DNS provider? What does your managed certificate log say?
To be honest I have no clue what I’m doing. Is there a good site that has a how to? I need it to work with a CTW certificate to go to a desec.io URL. I got it to work once wit Lets Encrypt, but after 90 days it didn’t renew. I thought I’m a buy one from CTW maybe that would be easier, and nope it’s not. Sometimes looks like its good in the CTW app, but does nothing on desec.io end.
We don’t sell certificates at all. Our software is used to order and renew certificate for Certificate Authorities (like Let’s Encrypt). Without trying to be insulting comments like that are a signal to us that you should get someone else to manage your certificates for you, it’s a technical task and if you can’t tell if we are selling certificates or software you would probably benefit from a local IT company taking charge of your setup.
We can only help if you give us actual logs and tell us the problem in detail.
If you summarize at a super high level we can’t help, because we can’t tell what you are doing right or wrong. You’ve mentioned “a script”, “a subdomain” etc.
Can you try starting from the beginning and totally explain in painstaking detail, perhaps with screenshots?
